'61 Distributer Hold Down - NCRS Discussion Boards
  • Richard P.
    • July 31, 2001
    • 173
    What is the correct distributor hold down for '61, 283/230 ? There are two listed in parts catalog- one "flat" and one "wire-style".
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: '61 Distributer Hold Down
    All of my original straight axle cars had the Flat style.
    HaND
    • David K.
      • February 1, 1976
      • 592
      Opps, please check that, they were wire style. Flat style is the replacement.
      • John D.
        • December 1, 1979
        • 5507
        Richard, Not an easy question it seems. Now I am not that up on 61's but as far as the FI restos goe I use the pie shaped flat steel ones on 57 to 60. Then I use the wire types on 61 to 65. Don't know if that is correct though but I don't seem to get complaints. John
        • Mike E.
          • February 28, 1975
          • 5141
          61 and 62 were definitely the wire type.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17940
            57 FI distributor hold downs were wire type. Gary....
            NCRS Texas Chapter
            https://www.ncrstexas.org/
            • Bob B.
              • March 1, 2003
              • 831
              The more expensive and higher quality A-shaped flat holddowns were used early on and sometime into the 1960 model year when they were replaced with the cheapie wire type. So, you should see the wire type from about mid-1960 model year on. - Bob
              • Jim D.
                • 2885
                1960 #3714 (built in Feb. 1960) has a flat one.
                Right or wrong, the 58-60 judging guide says that the wire types were not used on Corvettes.
                • John D.
                  • December 1, 1979
                  • 5507
                  When I was a kid we threw the wire type away and put on the good heavy duty steel ones.
                  • Jim D.
                    • 2885
                    The pictures in the assembly manual and Noland Adams book clearly show the flat hold downs for the 56-57's. I never saw a wire one until the 60's on a pass. cars.
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      For me all C1's used the flat design BUT 62 ??? I never owned a 62
