1960 horn relay - NCRS Discussion Boards
1960 horn relay
  • Jeremy H.
    • January 1, 1999
    • 260
    1960 horn relay
    I am trying to get a non-original 60 started. The last thing I have to get wired together is the horn relay. I do not have an original horn relay. Have the original wiring harness. How do I wire in another (67 corvette horn relay) relay? The 60 is not available and the 67 one has more than 3 connections. thanks for your help.
    Jeremy Hedges
    #31711
  • John F.
    • March 23, 2008
    • 2418
    Re: 1960 horn relay
    I just got a 3 terminal relay from Corvette Central for my 62. Works fine. I had to have the horns rebuilt since the originals were shot.
    • Michael L.
      • July 31, 2005
      • 562
      Re: 1960 horn relay
      Most local auto parts stores carry them as well. Not original, but they work. Got mine at NAPA
      • Christopher R.
        • March 31, 1975
        • 1599
        Re: 1960 horn relay
        Don't know anything about a '67 Corvette horn relay. But relays only need 3 terminal to do their job. The extra terminals are probably just convenient power take-off points.
        Can you find 3 terminals marked "H", "B", and "S" on your relay? If so, you should be able to make that relay work. I believe those letters stand for "horn", "battery" , and "switch".
        Run a wire (black) from the "H" terminal to the horns.
        Run a wire (red) from the "B" terminal to a 12v power source. There's a 12v power source in the wiring harness.
        Run a wire (tan) from the "S" terminal to the horn button.
        • Mike M.
          • May 31, 1974
          • 8408
          Re: 1960 horn relay
          the 67 horn relay is a press fit between the wiring harness connectors and the horn relay(ie, no screws ). as i recall, the c-1's fasten the horn harness to the horn relay with three slotted screws so if you have an original harness, you'll have to butcher it at the relay. as mentioned previously, go to a napa store and ask for a 57 chevy pass car- era horn relay. mike
          • Jeremy H.
            • January 1, 1999
            • 260
            Re: 1960 horn relay
            Thanks everyone, that answers my question.
