I just completed installation of my new clutch assembly and am ready to reinstall my transmission.
The transmission is an early model Muncie, and I am installing a new Hurst shifter purchased from Corvette Central.
Can anyone advise as to whether I can install the transmission WITH the shifter installed on it, or if I have to install the shifter after the transmission is in place? Or is it possible to pre-install and adjust the shifter, remove it, install the transmission, then put the shifter back on? (confusing I'm sure).
I know that when I initially removed the transmission there was very little clearance for the installation, and I'm not sure there's room to adjust the shifter after everything is back in the car.
I check previous posts, those focused on installing the engine and transmission at the same time.
Thanks everyone.
Thanks everyone.
