62 Cabin heat - NCRS Discussion Boards
62 Cabin heat
  • John F.
    • March 23, 2008
    • 2409
    62 Cabin heat
    Has anyone bought insulation for the floorboards? Where can you get it? And how thick? I will be installing new carpet soon.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17679
    Re: 62 Cabin heat
    John, have used the hot rod stuff on my '64 and works ok. Can't get it too thick or the carpet won't fit right. On my '57 put in some of the radiant barrier material which is a little thinner. Can't tell you which provides the best heat reduction. Best heat reduction I've seen so far was on a '66 BB driver. The firewall and underbody was sprayed with pickup truck bedliner and it really cut the firewall heat down alot. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • John F.
      • March 23, 2008
      • 2409
      Re: 62 Cabin heat
      Gary, Where did you get the stuff from?
      • Gary C.
        Administrator
        • October 1, 1982
        • 17679
        Re: 62 Cabin heat
        John, sorry should've put that info in my previous post. The street rod foil insulation comes in about a 6x6 ft roll or longer and it's at all the swap meets or check a street rod supply shop. The radiant barrier foil is at Home Depot and Lowes. Corvette Central insulation we put on a friend of mine's '57, but it comes in precut sections and we used 2 sets to do 1 complete floorboard, transmission tunnel and under the seats. Don't recall if there's any insulative value or "R" rating on any of the stuff.
        NASCAR uses a product by the name of Kool Mat. Here's their link:
        http://www.koolmat.com/main.htm Gary....
        NCRS Texas Chapter
        • Bruce B.
          • May 31, 1996
          • 2930
          Re: 62 Cabin heat
          John,
          I have insulated 2 62 Corvettes with a material called Dynamat and it is great. It is a foil face 1/8 inch thick sound and heat barrier. It comes in sheets around 20" by 32" and has a peel off liner which then exposes a self stick back. Just cut and fit and it is ready to install carpet over.I put in on the floor and firewall and there is a noticeable difference in cabin heat. It is sort of expensive but Google it and it is about half price compared to most dealers. I have attached a few pictures to show it.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17679
            Re: 62 Cabin heat
            Bruce, have you measure with bare fiberglass and the dynamat with a temp gun? Just curious of the with and without temperature differences. I've not done that on my '57, but will tomorrow on my '64 & post the results. Incidentally, you might think about putting something under the big FI gasket on your '57 to help reduce spyder temp and fuel boiling point. Just food for thought. Gary....
            NCRS Texas Chapter
            • Terry R.
              • March 1, 2005
              • 359
              Re: 62 Cabin heat
              There is an excellent article on insulating your Corvette in the Spring,2008 "On Solid Ground" by Verle Randolph.
              • Anthony S.
                • September 3, 2007
                • 107
                Re: 62 Cabin heat
                John,
                I had my carpets replaced a few months ago and prior to installing the new carpeting we used a product from Ecklers: http://www.ecklers.com/product.asp?pf_id=32598&dept_id=1628
                The addition of the under-carpet insulation along with replacement of all the under-body insulation decreased the cabin temperature immensely.
                There are two kinds of friends; the friend you call to bail you out of jail and the friend sitting next to you in the cell saying "Damn, that was great"!!!
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17679
                  Re: 62 Cabin heat
                  John, '64 temp measurements after 15 minutes of run time - from the "hot rod" insulation which has a pad on the bottom side and foil on the top side:
                  - 143 degrees Engine compartment firewall near pass side exhaust
                  - 133 degrees Pass inside foot well at same measurement point with insulation pulled down
                  - 93 degrees on insulation foil at same measurement point
                  Gary....
                  NCRS Texas Chapter
                  • Dennis A.
                    • April 30, 1999
                    • 1010
                    Re: 62 Cabin heat
                    Both Dynamat and Hushmat are excellent products, August Hotrod has good article on this subject. Eastwood has both brands.
                    • Bruce B.
                      • May 31, 1996
                      • 2930
                      Re: 62 Cabin heat
                      I did some non-scientific temp. measurements on my driver 62 (Dynamat insulated) with the following results;
                      Firewall where carpet ends in right footwell ,150 degrees F.
                      Same general area covered with Dynamat, 115 degrees F.
                      Below above area covered with carpet, 111 degrees F.
                      The above temps are an average of 3 measurements.
                      I also measured in a similar area with the original 45+ year old original GM firewall insulation and found a temp differential of about 35 degrees which approximates the Dynamat temp differential.
                      Bruce B.
                      • John F.
                        • March 23, 2008
                        • 2409
                        Re: 62 Cabin heat
                        Thanks guys for the info. The price at these places is all over the board. If you had to do it all over again. What brand would you pick?
                        • Bruce B.
                          • May 31, 1996
                          • 2930
                          Re: 62 Cabin heat
                          John,
                          I like the Dynamat as you can tell. I usually get thier bulk pack of 9 sheets. 3 packs will do 2 roughly C1 Corvettes.
                          Check out the price at hifisoundconnection.com which is where I have bought mine a few times.
                          Burce B.
