Original 270 coil - NCRS Discussion Boards
Original 270 coil
  • Bill L.
    • February 1, 2004
    • 1403
    Original 270 coil
    What should I do with an original coil that worked but is 38 years old? Should I have it redone or just buy a replacement? R the replacements correct?
    Bill
    • 43247
    Re: Original 270 coil
    Bill
    Bill-----
    I think I'd keep using it if judging is a consideration and you don't drive the car too much, anyway. Otherwise, install a new Delco coil for the road and save the original for judging. It's pretty easy to swap these things out.
    The reproduction coils are close but not 100% correct in every nuance. But, you really don't need to get involved in that. Just do as described above.
