C3 Blackout or Carpet - NCRS Discussion Boards
  • Frank B.
    • April 30, 2002
    • 66
    Should the back wall of a 71, C3 Convertible with Air Conditioning be blacked out or body color? What is the approximate distance from the top of the carpet to the top of the wall at the center.
  • Don L.
    • August 31, 2005
    • 1005
    Re: C3 Blackout or Carpet
    A good question, and one for which I too am interested in an answer/solution. I hope that by posting this, it'll raise it to the top and someone will be able to help.
    Don Lowe
    NCRS #44382
    Carolinas Chapter
      • 11668
      Per my 71 and 72 coupes, and Dad's convertible, the "back wall" is natural (dark gray) fiberglass.
      Patrick
      • Frank B.
        • April 30, 2002
        • 66
        Thanks for your reponse, but I think we need more. I looked at a 71 convertible with AC and the carpet only went up to the bottom of the Flow Through Ventilation doors which of course are blanked off being a AC car. . It was blacked out above the carpet. Convertibles may be different because of the opening of the deck lid. I would like to hear more.
          • 11668
          I'll double check the convertible today when I'm out there.
          • Frank B.
            • April 30, 2002
            • 66
            Patrick, thanks I am looking forward to what you find on the Convertible.
              • 11668
              I looked, but couldn't really tell. When I installed new carpet several years ago, it goes high enough that you really don't see the back wall enough to answer the question. So, that doesn't help you much.
              The AIM "may" tell you if blackout was spec'ed to be applied.
              Patrick
              • Gordon H.
                • August 31, 2006
                • 43
                On my 71 original 1 owner convert the carpet goes to the bottom of the vent doors .The fiberglass has overspray from painting the doors black .
                • Chuck S.
                  • April 1, 1992
                  • 4668
                  An AC car would not have the Astrovent doors; the Astrovent door openings are covered with gasketed stamped steel covers on AC cars.
                  In any event, the covers, and the doors, would have been prepainted before installation...I suspect the overspray you're seeing is from the blackout of the rear plenums that the doors open into.
                  I didn't respond to this question before, because I am unfamiliar with convertibles. But as Patrick responded, I believed the rear bulkhead would be raw fiberglass as on the coupes. GM didn't spend money to apply paint unless it was to cover "ugliness" that was easily visible...the rear bulkhead is hardly visible, and the raw fiberglass was not exactly unpleasant to see. In fact, the new cars don't even bother with blacking out the inner fenders anymore; they are raw fiberglass (don't spill any oil on them...you'll have a permanent oil stain).
                  Edit: Frank, I just read your later post about the blackout above the carpet on the 71 convertible. Since the rear bulkhead on a convertible is more visible when the tonneau cover is up, I suspect you are correct about that area being blacked out IF body color overspray came through the plenum onto the top of the rear bulkhead (I assume 71 converts still have the rear plenum). They would have covered any body color overspray with blackout.
                  • Chuck S.
                    • April 1, 1992
                    • 4668
                    ...The AIM "may" tell you if blackout was spec'ed to be applied...
                    Actually, Patrick, the AIM does not address any of the blackout areas. In fact, all of the paint operations are a "black box" as far as the AIM is concerned...you pretty much have to look at an original car to see what was done.
                    • Robert R.
                      • May 31, 1975
                      • 358
                      Frank and Chuck,
                      I hope this helps for your '71, but while looking at the '73 AIM for something else, I saw the page regarding this topic. It shows that for AC cars that the whole bulkhead gets blacked out, but for non-AC, that the vent area should be masked off.
                      Bob
                        • 11668
                        Originally posted by Robert Ricchio (599)
                        Frank and Chuck,
                        Bob
                        Bob,
                        Any chance you could scan and post that? Or reference the page?
                        Patrick
                        • Robert R.
                          • May 31, 1975
                          • 358
                          Pat,
                          Sorry that I could not scan, but here is the info.
                          The page per the AIM is: Section A01 to A12 Sheet 13.
                          If looking at Mid America's version, this sheet appears on their page 41.
                          Bob
                          • Harmon C.
                            • August 31, 1994
                            • 3228
                            I checked out a 71-2-73's and 75 all convertibles and all had blackout over body color from the top of the capet to 1" above the doors or plates. It stoped on both ends where the fiberglass turned to the rear.
                            Lyle
                            Lyle
                            • Chuck S.
                              • April 1, 1992
                              • 4668
                              Pat,
                              If looking at Mid America's version, this sheet appears on their page 41...
                              GM must have changed how the AIMs were organized.
                              The earlier AIMs have UPC "sections"...from the low Mid America page number you reference, that sheet should be UPC 1, or body "Bolt and Weld". Nothing in the 70 AIM fits that description...interesting.
