C1: Alignment specs - NCRS Discussion Boards
C1: Alignment specs
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12729
    C1: Alignment specs
    I forgot my ST-12 at our workshop but I'll get my '59-er aligned tomorrow. Does anyone has the camber and other wheel alignment settings at hand so I can pass them to my garage to get everything just right?
    thanks,
    Rob.
    Rob.
    NCRS Software Developer
  • Gary C.
    Administrator
    • October 1, 1982
    • 17648
    Re: C1: Alignment specs
    Rob, here's alignment info. Gary....
    Caster 2 degrees +/- 1/2 degree
    Camber 1/2 degree +/- 1/2 degree
    King Pin Inclination 3 1/2 to 4 1/2 degrees
    Toe In 1/16 inch to 1/8 inch
    Toe Out on Turns; Inner 20 degree +/- 2 degree, Outer 24 degree +/- 2 degrees
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12729
      Thanks Gary!!!
      Rob.
      • Gary B.
        • September 30, 1987
        • 305
        From my notes for my `62,\.
        Assuming (which one should never do) all is well with the front end. Set the toe-in at 0 to 1/16th and the caster to the maximum. Caster should not affect tire wear but this setting is better suited to radials.
