54 Stalling issue- Take 2 - NCRS Discussion Boards
  • Joe R.
    • July 31, 1994
    • 287
    My 54 six cyl. has an occasional stalling issue. When driving it in high ambient temps, it will occasionally sputter and stall at idle. The coolant temp is running at around 190 deg F when it is 90-95 ambient, some stop/go traffic. It will always start back up with a few cranks.
    I have set the floats at 1/2" on recommendations from others in the archives, but nothing has changed except less leakage out the venturies!
    Any ideas as to where to look? Is this "percolation"? And if so how can I resolve
    Joe
  • Gary C.
    Administrator
    • October 1, 1982
    • 17768
    Re: 54 Stalling issue- Take 2
    Joe, try a higher idle speed somewhere around 900 and see if that helps any. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Clem Z.
      • January 1, 2006
      • 9427
      use a needle/seat out of a turbo corvair carb kit as it is a spring loaded one that the vibration from the engine will not affect.
      • Joe R.
        • July 31, 1994
        • 287
        Thanks guys.
        I have the spring-loaded needle/seats in all 3 and I tried the higher idle speed. I'm now at about 875 in drive. Maybe I'll try higher, as you suggested, Gary.
        I was wondering if my heat riser is in the wrong position? Do you guys have a picture of where it should be when hot?
        • Clem Z.
          • January 1, 2006
          • 9427
          have you check your fuel pressure ?????
          • Joe R.
            • July 31, 1994
            • 287
            I did. It runs at about 4-6 PSI at idle
            • Ted K.
              • August 31, 1994
              • 337
              The heat riser spring should be reversed causing the flap in the manifold to be in a open fixed position all the time. This came out in some directive from GM in 1954.
              • Joe R.
                • July 31, 1994
                • 287
                Ted, do you know the position of the weight in the correct way?
                • Ted K.
                  • August 31, 1994
                  • 337
                  Unfortunately I am not with the car to describe the position, but when the engine is cold the convertional setup was to have the bimetal spring holding the heat riser closed until the manifold is sufficently hot to allow the spring to open up the internal flap. When the engine is cold observe this position, warm up the engine and see if the heat riser opens up. If it does reverse the spring so that it holds the heat riser open all of the time.
