radio - NCRS Discussion Boards
radio
  • Sal R.
    • December 10, 2007
    • 160
    radio
    I have a 1986 that has a Sony radio in it now .I have the original radio any tricks on how to install.
  • William C.
    • May 31, 1975
    • 6037
    Re: radio
    Two questions, were the speakers changed? If so you will need to "recreate" the original Bose speaker set to use the original Radio. The Bose system uses a discrete amplifier located in each speaker box, and most "replacement" radios use a more conventional speaker system. After this is under control, step two is the issue of how much cutting and splicing was done and will not usually be evident until the radio is removed from the dash and you can inspect the wiring.
    The usual problem with older Bose systems is that the capacitors in the amps located in the speaker housings go bad. The amps can be rebuilt relatively inexpensively with good results.
    Bill Clupper #618
    • Sal R.
      • December 10, 2007
      • 160
      Re: radio
      No damage done at all putting in the Sonny all original speakers are still in car no problem getting raido out kind of just slides in there it's the original radio I cant figure how to get back
      • William C.
        • May 31, 1975
        • 6037
        Re: radio
        Let me understand the question, you have the original radio and need to know how to return it into the dash assy, or you need an original radio? If the first is the issue, the Service manual has a pretty good description of the process to R & R the radio. I had to do it once and it's just a matter of keeping track of exactly which hole each screw goes back into and taking it step by step. Otherwise the radios are available from eBay or a variety of boneyards with C-4 parts hordes.
        Bill Clupper #618
        • Sal R.
          • December 10, 2007
          • 160
          Re: radio
          Thank you for the help
