I would like to remove the old paint from the underside of my hood and apply a new finish. What would be a good way to remove the old, blistered paint without risking damage to the surface of the hood? My concern is that some paint strippers may leach through the fiberglass and damage the paint on the outer surface of the hood. I have read that you should never use sandpaper on fiberglass. I would also like to know what paint is recommended to refinish the underside of the hood?
Thank You
Thank You
As long as it dries thoroughly, I have found that it's the best way to positively remove contaminants. Why, hell, you can even bathe in the stuff to get the grease out from under your fingernails! It DOES cause irrevocable brain damage, though.
