59-61 FI fuel filter - NCRS Discussion Boards
  • Lou C.
    • August 31, 1992
    • 134
    I was working on a 1960 290 HP fuel car a few weeks ago. The car was flooding, gas pouring out of the vent on the fuel bowl.
    Made a call to JD in Pittsburgh for some trouble shooting ideas. After the call I removed the needle and seat and found a small piece of epoxy stuck under it. Where did it come from? Time to call John again.
    It turns out I have a repro 59-61 fuel filter that was sold some time ago.
    It was put together with epoxy. The epoxy breaks down over time and then you have a problem.
    Has this happened to anyone else?
  • Don H.
    • December 1, 1981
    • 1486
    Re: 59-61 FI fuel filter
    Lou,
    I am not an expert but have seen what you describe. I silver soldered my fuel filter, not original but never leaks.
    Don H.
    • Lou C.
      • August 31, 1992
      • 134
      Don, If I remove the epoxy I can see on the outside will it come apart? How did you get it apart?
      Lou
      • Don H.
        • December 1, 1981
        • 1486
        It has been a long time but I think it will not come apart. The fitting is crimped in and the sealant is to seal it. I think I removed what epoxy I could and then soldered. Don H.
