1963 hood prop - NCRS Discussion Boards
1963 hood prop
  • Timothy B.
    • April 30, 1983
    • 5202
    1963 hood prop
    Yesterday, I was going through some parts I saved and discovered something about my 63 hood prop that I wanted to share. When the hood prop is extended there is no hole for a safety bolt like the service replacement hood prop that's on the car now. Does anyone know when these parts started with the hole for a bolt for safety.
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 1963 hood prop
    Tim;
    Mine is a July 9/63 build and it does have the bolt hole. I never used it as I use a small "C" clamp instead. I lost a model of an SS racer that I had on the air Cleaner once due to a wind gust. That model at less than $100. was my least concern. I now have a little spider in the paint where the hood took the hit from underneath. The "C" clamp is not as neat as a bolt, but it's a conversation piece.
    Stu Fox
    • Bill M.
      • April 1, 1977
      • 1386
      Re: 1963 hood prop
      I was working on my '59 in the apartment parking lot when a gust of wind closed the hood for me. My head got caught between the hood and the fender. It was a very hard hit, but apparently I have a harder skull. (If the edges of the fiberglass weren't rounded, I would have been sliced wide open.) I now carry a small bolt in the glovebox...
      • Guest
        Re: 1963 hood prop
        Tim,
        great question! not sure of an answer - my July 11 built car has the support with the hole in it
        • Bob J.
          • December 1, 1977
          • 720
          Re: 1963 hood prop
          Tim,I believe that hood prop missing the hole is a 1964 prop. It was suppose to have the hole and Chevy issued a bulletin to drill the hole when those cars built without the prop hole returned to dealers for service.Bob
          • Norm B.
            • 360
            Re: 1963 hood prop
            Tim,
            If I remember correctly from our correspondence a couple of years ago your car was only built a week or two after my late October car. Just looked at mine and it has the hole.
            Norm
            Golf is for those who can't play​ hockey.
            • Timothy B.
              • April 30, 1983
              • 5202
              Re: 1963 hood prop
              Thanks everyone for there responses, here are two pictures of the hood prop I am refering to. It's odd that 63 got this correct with regard to the holes but 64 is not drilled. I assume this hood stay is a 64 part.
              • Stuart F.
                • August 31, 1996
                • 4676
                Re: 1963 hood prop
                Tim;
                Next time line up the holes on the slidee and the slider so we can be sure it's legit - (Ha!)
                Stu Fox
