Nylon vs Brass Button? Distributor Cross Gear - NCRS Discussion Boards
  • Roger D.
    • May 4, 2008
    • 301
    I have a 1972 coupe with 350/200. I need to replace the nylon button that serves as the thrust bearing surface for the tach drive gear (or cross gear) inside my distributor. I think they started putting these in distributors in '71 to protect the housing. Most parts places stock a brass button as a service replacement for the original nylon button. You can still get the ny lon button also. Anyone had experience with installing the brass button as a replacement? Recommendations?
    Thanks in advance!!
  • Timothy B.
    • April 30, 1983
    • 5195
    Re: Nylon vs Brass Button? Distributor Cross Gear
    Roger, I would install, the nylon button that's a good design.
    • William C.
      • May 31, 1975
      • 6037
      Second the nylon button for the later distributors fitted to use it. The brass button is primarily a repair item for cases where the housing has been eaten by the gear in the applications prior to use of the nylon button.
      Bill Clupper #618
        • 43247
        Thanks in advance!!
        Roger-----
        The nylon button will last longer than you will. Unfortunately, the button, GM #1957329, is long-since GM-discontinued, and I don't know of a source for it. There may be one, though.
        • Roger D.
          • May 4, 2008
          • 301
          Fellas....I found the nylon button and bought one from Bair's. Check out item #1952 (4th item from the bottom of the page)
          Thanks for your help. I'll let you know how it goes.
          Roger
          • Gerard F.
            • June 30, 2004
            • 3806
            Roger,
            Thanks for the source, I just ordered one too. I think with the brass button, you have to pull the distributor shaft to install it. With the last nylon button I didn't have to.
            But they do wear out faster than the brass button.
            Jerry Fuccillo
            • Roger D.
              • May 4, 2008
              • 301
              Jerry, You're welcome. Yes I called Bairs this morning and they said that someone else just ordered one also. Yep, they didn't charge me any shipping so $2 got me the new nylon button. Hope it works.
              Roger
              • Gerard F.
                • June 30, 2004
                • 3806
                Roger,
                Unbelievable! I received the nylon button from Bairs tucked into the center of one of their catalogs. Cost $2.00 plus 75 cents frieght, $2.75 total.
                I know where my next big order is going.
                Jerry Fuccillo
                • Roger D.
                  • May 4, 2008
                  • 301
                  Hey Jerry. Yea I got mine yesterday the same way. Pretty cheap. I spoke to them on the phone earlier this week and they seem real friendly. I will probably order from them again. They were the only parts place I found that carried the nylon button (although I did not look much further after I found this one since it was only 2 bucks). Anyone else had any experience with Bair's?
