I read the long thread on this question and have a similar question.
I just had the steering box on my 1969 rebuilt by a reputable shop. The alignment was fine before I took it off. When I reinstalled it with the flat spot at 12 o'clock there was a lot of drift when driving straight. I took the box off and from the high point the shaft turns two turns to the right and 1 3/4 turns to the left. From what someone said in the other thread this difference isn't enough for the worm gear to be a tooth off the sector gear. Does the flat spot need to be exactly halfway between the two end points?
I was going to take it back where I got the box rebuilt. Is it likely that it was set up incorrectly? The alignment was ok before I took it off.
Align everything by the book and adjust tie rod ends to center tires straight.
