61 PCV emission valve - NCRS Discussion Boards
    • 43259
    Re: 61 PCV emission valve
    Originally posted by Richard Geiger (19279)
    I purchased my 61 270hp car in '68. I am second owner. It is a California car with PVC smog stuff. None of the fittings are painted they are plated a sliver gray color. The hose to the base of the back carb has AC markings in white.
    Ray-----
    What part number is stamped on the valve? It will be small font size; you will probably need a magnifying glass to see it clearly.
    • Stuart F.
      • August 31, 1996
      • 4676
      John;
      I thought I sent a reply acknowledging yours to clarify that I was only referring to the "Draft Tube" end as a point of reference. I know there isn't a draft tube parse, but I didn't know from my bean what to call that end of the connection. It appears some other replies on this thread were dropped off too. So what did I do? swear? or say some politically incorrect word? Maybe the word "Draft" is sensitive to some Dodger fans out there, Ha!
      Stu Fox
      • Richard G.
        • April 30, 1991
        • 68
        #18
        Jo, I just went to the shed to look for the number on the PVC valve. All I could see was a circle on the body of it. I must also apoligise because I may have mislead some readers of the board. The PVC valve itself is actually black in color-don't know if it was a type of plating or paint. The cone shaped piece that goes into the block that the PVC valve attaches to is silver/gray plated. Next serious engine clean, when I have the shielding off, I'll have a closer look at the valve for numbers. Sorry I couldn't be more help.
