'62 Radio Shielding - NCRS Discussion Boards
'62 Radio Shielding
  • David K.
    • February 1, 1976
    • 592
    '62 Radio Shielding
    I have looked and studied the AIM, but I still can't seem to get it right on the right side radio shielding. I am assuming that the "J" nut will clip to the spark plug shield. The right vertical shield will go over this spark plug shield and the notch in the vertical shield will slip under the wing nut that goes into the "J" nut. Is this correct?
  • Mike E.
    • February 28, 1975
    • 5141
    Re: '62 Radio Shielding
    Dave--
    Going from memory here--but seems to me the j-nut goes on the end of the vertical piece, and the wing nut goes through the horizontal and into the j-nut that's on the bottom of the vertical.
    • David K.
      • February 1, 1976
      • 592
      Ok, thanks. I have tried about every way I can think of. It was easy to get the rest of the shields mounted, but this one is a test!
