Hello All, I am new to the forum and could use some help. I just purchased a 66 roadster with a L72. I was initially experiencing overheating so I first inspected the timing to find it jumping 20 degrees back and forth around TDC. I replaced the cap, rotor, points, plugs and wires but this did not help. I pulled the distributor and sent it to the shop. It is tight with new springs and the proper amount of shaft end play. Still jumping but slightly better. It use to be transistorized but someone gutted the distributor and put in points. The old module is still bolted to the drivers side fender well. I then replaced the timing chain and sprockets with a new set but still jumping. I have been able to fix the over heating by replacing the coil with a newer coil and resistor (I think it was related to the resistor) but the timing is still jumping around. I have set the timing by sound and feel but do not like this method since I could be off. The engine runs great and has plenty of power, no knocking or run on after shutting it down. I also purchased a new timing light still no difference. I have worked on car for a very long time and never seen this much variation. Any help would be greatly appreciated.
