C1 (early '57) Radiator Support question - NCRS Discussion Boards
  • Rod K.
    • 443
    What "shade" of black was used for the radiator support shell prior to "black out"d, semi-gloss?
    Also, what bolt head markings are correct for the support to body and for the horn mounting brackets?
    TIA
    Re: C1 (early '57) Radiator Support question
    Rod -
    The radiator support was dip-primed semi-gloss black before it was assembled into the front clip.
    • Rod K.
      • 443
      Thanks, John. As I suspected. Any ideas on the bolt head markings or sources to find that info?
