'55 door gaskets - NCRS Discussion Boards
'55 door gaskets
  • Michael L.
    • July 31, 2005
    • 562
    '55 door gaskets
    Ok, I see plenty of photos of the rear of the dood where the gasket is placed, where does it stop on the hinge side? How far up on the door does the gasket run by the hinges? Anybody have a pic?
    Thanks,Mike
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '55 door gaskets
    Thanks,Mike
    The rear of the DOOD hay DUD you dint more pic's when you were up here I dont have a pic. but it's the same as 54 check Nolands bible book
    • Michael L.
      • July 31, 2005
      • 562
      Roy, checked that before I posted. Plenty of pics on the striker side, none on the hinge side. If I can't find a pic , I'll try fitting the door and getting a visual where the gasket would make contact. Thanks,
      Mike
