1963 Loss of Power on Acceleration - Solved!!! - NCRS Discussion Boards
  • Joel T.
    • April 30, 2005
    • 765
    Hi All;
    I know a number of you have been following and contributing to the threads which I started regarding my 1963 stumbling on acceleration. I am happy to report that the problem has been solved.. All of you who called out "fuel" should get a gold star (or perhaps a gold Corvette sticker). The problem was fuel after all but there were some ignition issues as well.
    What it turned out to be is the sock on the fuel pick up. When I did the mechanical restoration on the car I bought a new fuel sender. The sock on the end of the sender was folded over to get the whole thing to fit in the box. I should have slid the sock all the way down on the fuel pickup tube to eliminate the fold and to fully set it on the tube... Duh! Evidently, the fold in the sock was right over the fuel inlet causing a blockage and I would imagine that the folded sock was stuffed right under the pickup tube as it lay on the bottom of the tank..
    I removed the fuel pickup, pushed the sock all the way down onto the tube, blew out the line (nothing but fuel in it BTW) and reassembled and with 5 gallons of saved gas head off down the street. It now runs like a watch, not a stumble to be had....
    I guess this is one for the books! Anyway my sincere thanks to all of you who pitched in with your thoughts and ideas. While it was not the core problem, this exercise provided the opportunity to straighten out some issues with my distributor as well. Tomorrow I will put the spare tire tub back in place and get the tank filled!!
    Regards!!
    Joel
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 1963 Loss of Power on Acceleration - Solved!!!
    Joel;
    Congratulations on solving your fuel problem. You used your good old American common sense and followed through. You should feel good about yourself and sleep well tonight.
    Stu Fox
    • Arnold P.
      • August 31, 2005
      • 48
      joel, you'll need to take out a mortgage to fill'er up!!
      • Tom H.
        • December 1, 1993
        • 3440
        Great news !!! Glad you found the problem.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Timothy B.
          • April 30, 1983
          • 5196
          Joel,
          Glad to hear you found the problem with the 63. Tim
          • Gary S.
            • July 31, 1992
            • 1633
            Thank you for the follow up. So many of us ask for advice and then fail to report back whether or not the problem was solved. I learn as much from the advice given here as I do from the resolution of the problem.
            Gary
            • David D.
              • January 1, 2005
              • 416
              Joel,
              Great news.....now go out and drive her WOT.
              David
              • John D.
                • December 1, 1979
                • 5507
                Joel, That fix was one for the books. Congratulations. John D.
