63 Wiper Motor/Washer Pump Wiring Question - NCRS Discussion Boards
  • Kenneth B.
    • April 10, 2008
    • 39
    Hello, folks,
    Today I'm finishing up the wiring in the engine compartment. However, I need some assistance before I can proceed.
    I am currently working on the windshield wiper motor & washer pump.
    I need to know the wiring orientation of the two-pronged plug that goes to the washer pump. I removed the wires from the plastic harness fixture that holds them (in order to clean it), and I neglected to label them.
    (I know, dumb, dumb, dumb).
    There are two wires that go to the pump, a brown one and a white (natural?) colored wire. Looking straight at the washer pump, which wire should be on the lowest prong?
    Thanks in advance for your assistance!
  • Timothy B.
    • April 30, 1983
    • 5178
    Re: 63 Wiper Motor/Washer Pump Wiring Question
    Ken,
    See if the picture of the 63 harness helps out. If not I will remove the top shield to get a better picture.
    • Kenneth B.
      • April 10, 2008
      • 39
      Originally posted by Timothy Barbieri (6542)
      Ken,
      Hello, Tim,
      Thanks for the response. I know which two wires are connected to the pump, I just don't know which one goes on which terminal (or if it even makes a difference).
      So, the picture would be great.
      Thanks again.
      • William C.
        • May 31, 1975
        • 6037
        Looking at the connector from the bottom (slots facing you) 94 circuit (white is on your right and the 4E (brown) is on the left.
        Bill Clupper #618
