C2 Fuel Sending Unit False Reading - NCRS Discussion Boards
  • Mark P.
    • July 31, 2003
    • 407
    I pulled my 66 fuel tank to repair a slight leak and after repairing it and re-assembling, found that the gauge reads 3/4 full with only 5 gallons in the tank. After moving the arm, (lifting the arm up and down in the tank) it won't read below 3/4, but will read full when the arm is lifted to the top. What gives? I was very careful with the unit upon removal and disassembly. Contacts are clean and bright.
    What did I do wrong or is it just a sign of old age? (the sending unit, not me...or it could be me, too.)
    Any advice would be appreciated!
    Mark
    Mark Pugmire
    54 Pennant Blue
    56 Cascade Green Dual Quad
    56 Arctic Blue Dual Quad
    66 Nassau Blue 427 L36 Convertible
    67 Marlboro Maroon L79 Coupe
    Re: C2 Fuel Sending Unit False Reading
    Mid-year cars used a special circuit topology for the gas gauge (based on Whetstone bridge construction) making them independent of absolute B+ voltage. Typically, performance hiccups deal with wiring fault(s) especially getting good ground at the tank sender.
    The 1963 Corvette Shop Manual had a nice theory of operation + trouble shooting chart based on symptom. I'd attach a copy, but it's a 425Kb .DOC file and the site's attachment manager says the limit is 97.7 Kb for uploading .DOC files...
    • Mark P.
      • July 31, 2003
      • 407
      I've got the manual...I'll check it and see what it says. Thanks for the input.
      Mark
      Mark Pugmire
      54 Pennant Blue
