Lacquer Paint - NCRS Discussion Boards
Lacquer Paint
  • Richard P.
    • July 31, 2001
    • 173
    Lacquer Paint
    What is the best way to determine if my car has lacquer paint or has been clearcoated?
  • Gary N.
    • August 31, 1986
    • 118
    Re: Lacquer Paint
    When you wax the car do you get the color of the car on the buffing cloth or is it colorless? If it colorless it's probably got a clear coat on it.
    Gary Nyland
    1966 Black Corvette Air Coupe
    2014 Black Z-51, 3LT Coupe
    1955 Black Chevy Belair Gasser
    1955 Nomad
    • Terry D.
      • May 31, 1987
      • 2697
      Re: Lacquer Paint
      Richard
      In a not too noticable place, maybe under front grille, take a cloth with a little polishing compound and rub the paint. If paint comes off on rag it is not clearcoat.
      • Jay G.
        • August 31, 1993
        • 398
        Re: Lacquer Paint
        You will find paint start to get all over the polishing rag. Don't concentrate or linger too long on one spot. If its a 40 yr old lacquer paint etc. Will be kinda fragile.
        • Gary C.
          Administrator
          • October 1, 1982
          • 17865
          Re: Lacquer Paint
          Caution - some painters have been known to mix a little color in the clear so that you will get some color when it's rubbed on with compound. JMTCW, Gary....
          NCRS Texas Chapter
          https://www.ncrstexas.org/
            • 15706
            Re: Lacquer Paint
            If the door jambs and hood gutter are as glossy as the exterior, it's probably single stage enamel or basecoat/clearcoat.
            Single stage enamel will show color with polishing compound, but it will take more rubbing to get color on the rag than with lacquer.
            Another way is to lightly dampen a rag with lacquer thinner and take a swipe or two in a non-visible area like the valence panel underside. Lacquer will show color on the rag. Enamel or clear coat will not.
