1972 Column key buzzer - NCRS Discussion Boards
  • Denny J.
    • November 1, 2000
    • 244
    I'm cleaning off my desk. What I have is 100% match for the hard to find key buzzer.I took mine off the 1972 and tested the replacement.So far I have gotten 4 from ebay 8.00 to 12.00 each.
    I have all the numbers to the parts and the instruction on how to install.
    Also have a number to a warehouse who thinks he may have 25 pcs.But may want $50.00 each so use ebay cheaper.
    So off line if anybody want this info I will sent it to them.
    I will send it to 1 person only after that ask him.
    Dennis
    • 43288
    Re: 1972 Column key buzzer
    Dennis
    Dennis-----
    The 1972-77 buzzer, GM #6262663, is still available from GM. It GM lists for about 30 bucks, each.
    • Jim S.
      • August 31, 2001
      • 730
      Joe,
      Maybe I am confused as to the buzzer compared to the switch inside the steering column.
      I have the following key buzzer switches listed for the C3 steering columns:
      I can't find the number for the 1969-76 standard column buzzer switch. Although I believe that it is still available.
      1969-76 T&T Column buzzer switch 26022717. This switch is very rare!
      1977 Standard Column 7804414 Listed on GMPartsDirect
      1977 T&T Column 7811092 Not available on GMPartsDirect
      I believe that the 1977 switches carried through 1982.
      Jim
        • 43288
        Originally posted by Jim Shea (36737)
        Joe,
        Jim
        Jim-----
        Yes, the buzzer and switch are different pieces. The switch is what activates the buzzer and is, of course, contained within the steering column. For 1966-71, Corvettes used an ignition switch key buzzer that was integral with the horn relay. For 1972 and later, the buzzer was separate from the horn relay.
        The 1969-78 standard column switch was GM #7804414, as you described. This switch part number remained the same from its inception for 1969 right through to the present time.
        The 1969-76 switch for T/T column was originally GM #7804509. That part was discontinued in December, 1971 and replaced by GM #7811093. The latter part was discontinued without supercession in August, 1993. However, I think I saw somewhere that a reproduction/replacement of this switch is now available.
        The 1977-82 switch for T/T column was GM #7811092. It was discontinued in April, 1992 and replaced by the GM #26022717 that you mentioned. That switch remains available from GM.
