Temperature gauge problems - NCRS Discussion Boards
  • Lorne G.
    • June 30, 1988
    • 118
    Help, I can't figure what is wrong with my temperature gauge in my 67. The needle went way past the 250 degree mark ....as far off the gauge as possible. I checked all connections and everything seems good. I reversed the pink and green wires going to the gauge thinking i somehow reversed them, and the gauge needle then dropped back to normal. I ran the car a couple of times and the temperature gauge seemed to be working normal again. I just started the car again today and the gauge went way over the 250 degree mark again as soon as I turned the ignition switch.
    What is happening? Is the gauge faulty?
    Lorne
  • Scott S.
    • March 1, 1979
    • 747
    Re: Temperature gauge problems
    Lorne, A temperature sender is a variable resister to ground. The higher the temperature the lower the resistance. A shot circuit to ground will cause the guage to peg to full scale deflection. i hope this helps.
    Scott Sinclair
    • Tony S.
      NCRS Vice President, Director Region VII & 10
      • April 30, 1981
      • 993
      I had the same problem with the temperature gauge on my '67. It did not have good ground. Once I got it properly grounded, problem solved. Check your ground and I'll bet that's your problem.
      Good luck.
      Tony
      Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
      Original member of the Kansas City Chapter, est'd 07/11/1982.
      Member: 1965 and 1966 National Judging Teams
      Judging Chairman--Kansas City Chapter.
      Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
