not sure why we have to learn from mistakes...why can't we learn from successes? - anyway, i decided to teach myself how to use an arbor press this weekend to press out the trunion bearings on both drive alxles - in the process, i bent almost in half the "flange plate" (?) - the part that attaches to the other end of the drive axle and connects it with the wheel - the other one escaped my buthchery - the living part is "GM30A; 3843018" - I imagine that the dead part is GM30B - does anyone know which is the left and which is the right...i looked in the AIM but could not find this part even called out (was looking at UPC4A2 - it is where part "2" bolts (x4) go through).
As a separate question, from an NCRS judging perspective, is that a part that is judged? - given that I have one original, is it worth trying to find the other? - or are these considered "wear" items? - as for the half shafts (drive axles) themselves, one has a pretty good chunk (not from me!) our of the top portion where the retaining clip for one trunion bearing is - they are generally beat up and a little rough where the trunions are (PICTURES HERE http://s65.photobucket.com/albums/h2...0Half%20Shaft/) - again, are these items that are reproduced - the half shafts that is? - or should I make every effort to rehabilitate them? - thanks in advance for any advice, stephen
Only kidding you...all of us have a tale like yours.
