'61 T-10 Numbers - NCRS Discussion Boards
'61 T-10 Numbers
  • Richard P.
    • July 31, 2001
    • 173
    '61 T-10 Numbers
    Would these numbers look right for a BW T-10 tranny for a 1961, with a build date of Dec. 7, 1960?
    L 150-2,J22L, t10-1B ,and it looks like a date code 9-27-60
  • Mike E.
    • February 28, 1975
    • 5152
    Re: '61 T-10 Numbers
    There's an inconsistency there, if I'm reading it right---L150 casting would be November 15. If the date code is 9 27 60 (and that is the stamped code) then there's an issue. Knowing which of these numbers are stamped and which are cast, and on what components they are located would make it much easier for us to give you a more accurate answer.
    Mike
