I need to replace the cable boots on my '66 parking brake. What I believe are the originals are heavily ribbed and accordion-like. The replacements from LIC and Paragon are totally different, yet Paragon states that they are "correct." Below are a couple of photos showing the originals on the cable as well as the replacement. To add to my confusion (which is increasingly easy as I get older), there's no way that the replacement boot will fit over the ball at the end of the cable or the spring on the cable (see the first photo - original boot on top; replacement in middle; ball and spring on bottom). The original boots appear to have been installed prior to soldering the ball onto the end of the cable. I tried heating the replacement boot and spraying it with silicone, but the only way I can figure to get the boot over the ball is to slit the narrow end. Any thoughts on how to install? Will the replacement pass judging?
Much thanks,
Jeff
Much thanks,
Jeff
