54 Vacuum fluctuation - NCRS Discussion Boards
  • Joe R.
    • July 31, 1994
    • 287
    I am tuning my carbs on the 54 and connected a vacuum gauge to the intake manifold to read the idle vacuum. To my surprise, the gauge is reading a rapid fluctuation of between 12 and 19 in/HG. The engine seems to run fine, but I'm concerned about this. Any ideas, anyone?
    Joe
  • Terry R.
    • March 1, 2005
    • 359
    Re: 54 Vacuum fluctuation
    Hi Joe Sounds like a valve trying to stick to me. A little Marvel Mystery oil in the carbs will probably cure. I always put a little in the gas tank on the cars I don't drive regularly. Good Luck
    • Roy B.
      • February 1, 1975
      • 7044
      Top is a original design having the brass tag and you can remove the end nut to change spring tension.
      Bottom replacement no brass tag or end nut.
      • Wayne P.
        • August 31, 1975
        • 1025
        Are you "T" into the vacuum line. Hooking directly will cause the swings in the readings.
        • Joe R.
          • July 31, 1994
          • 287
          No, I hooked directly into the fitting for the trans vac modulator. Did not "T" into it. Why would this make a difference?
