1965 Radiator shroud attaching clips - NCRS Discussion Boards
  • Keith B.
    • December 1, 1991
    • 397
    Could someone please a post picture (detail) of a 1965 big block radiator shroud attaching clip. It is my understanding that they should have a square nut rather than hex nut. Any help would be appreciated.
    Keith Burmeister
  • Keith B.
    • December 1, 1991
    • 397
    Re: 1965 Radiator shroud attaching clips
    Still no help?????????
    Keith Burmeister
    • Wayne M.
      • March 1, 1980
      • 6414
      Keith -- checked my L78 when you first posted, but Bubbba's beat me to it . Anyway, here's a pic of the item from a July '65 P&A30 parts book. I'm surprised it doesn't list the AIM part # for this nut, which is 3792259. Also, the bolt is the same as regular production. There may be a 2nd weld bead on the opposite side of the square nut (which doesn't show).
      Maybe someone will post a pic of a real one.
      • Page C.
        • February 1, 1979
        • 802
        Hi Keith,
        These square type clips were also used in the fender to inter fender panel on old Chevy pick-up trucks in the late 60's. When you go junk yarding, take some PB Blaster as these clips are not the easiest things to remover without breaking the nut from the clip.
        Page Campbell
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1463
          Hi Keith
          I'll get a shot of my '65 and post it tomorrow.
          HaND
          • Keith B.
            • December 1, 1991
            • 397
            Still need help
            Keith Burmeister
            • Stephen L.
              • May 31, 1984
              • 3162
              BOLTS are square and swaged into the "J" nut holder. No welding involved.
              My 67 BB car had some square and some hex... got gigged for the hex... not worth the argument so I've changed to all square.
              Available from Restoration Specialties and Supply #1018J
              • Tom D.
                • September 30, 1981
                • 2138
                Paragon's 6124K is "Hex", but they tell you...
                Paragon points out that theirs are "not the same as..."
                TD
                https://MichiganNCRS.org
                Michigan Chapter
                Tom Dingman
