Tires for 1986 - NCRS Discussion Boards
Tires for 1986
  • Patrick S.
    Infrequent User
    • September 30, 1992
    • 12
    Tires for 1986
    I plan to replace the tires on my '86. Any suggestions on what is a good tire. I am looking for a nice touring tire, good in the rain, not a lot of noise. There are so many choices and I could use some input from people who have used a tire using the above criteria that they are satisfied with. I have looked at BF Goodrich g sports and Faulkens, both get mixed reviews on noise, wet traction and tread wear. First time on the board, hope you guys can help me out. Thanks for your time.
    • 43247
    Re: Tires for 1986
    Patrick-----
    You have a VERY narrow range of choices available to you, assuming that you are using stock wheels with stock size tires (P255-50-16), which is what I highly recommend you stay with. Neither Goodyear, Firestone, Bridgestone, or Michelin make a tire in your size. The only ones I know of in that size are the B. F. Goodrich and Falken that you mention as well as Dunlop Sport 8000. The latter are much more expensive than the B.F. Goodrich or Falken models in your size.
    So, your quest is just to find a tire that fits your car rather than to choose among a plethora of tires with different performance characteristics.
    • Stephen B.
      • April 1, 1988
      • 876
      Re: Tires for 1986
      I purchased some "cheapies" on eBay for my '86. After mounting and balance, I had $400 in a set. I believe they were Falkins and handled fine. My original wheels and tires are brought out only for judging.
      • James L.
        • June 30, 1986
        • 33
        Re: Tires for 1986
        Patrick
        Try www.Tirerack.com. They have a matrix input form to help you select tires with the charaacteristics you want. If you go with them their prices are fair and they'll direct you to a local mounting shop as well. Good luck.
        Jim
        • Keith B.
          • March 7, 2008
          • 928
          Re: Tires for 1986
          I have the BF Goodrich g sports on my 94 and they are great in the rain, and better on dry roads. And I think they are quite. I would buy them again
