How Do you Remove Scratches/swirls from Chrome Wheel Trim Rings - NCRS Discussion Boards
  • Paul C.
    • November 11, 2007
    • 511
    I have a 71 and the chrome wheel trim rings look good but when up close have lots of fine scratches,swirls--probably from wiping the brake dust off with a dirty rag. Any suggestions how to remove these? Thanks Paul
    • May 31, 1974
    • 8374
    Re: How Do you Remove Scratches/swirls from Chrome Wheel Trim Rings
    eastwood sells the Baldor buffing machines. or send it to a stainless steel polishing outfit. they add in the driveline.mike
    • Paul C.
      • November 11, 2007
      • 511
      Isn't thre any solution to this problem besides sending it out?
      • Jim T.
        • February 28, 1993
        • 5351
        Have you tried Semichrome paste polish or even some BRASSO which can be used on chrome and stainless steel?
        • Chuck S.
          • March 31, 1992
          • 4668
          For minor dust scratches, I would probably first try my Porter Cable polisher with rubbing compound.
          If that didn't get them looking nice, the next step would be a try a sewn cloth buffer wheel on my bench grinder using white rouge. This approach can be tricky if you're inexperienced...you can make them worse than they are now.
          • Jay G.
            • August 31, 1993
            • 398
            Try Mequiars Tech wax 2 Advt removes MINOR scratches and swirls. Used it on my 40 4 clip rings with great results. 8.5 out 10 dreiver Quality. See close up on my 67 SS 396 switched rings out for a show.
            • Harmon C.
              • August 31, 1994
              • 3228
              I have seen a swirl pattern in originals and thought it could have been their when they were new.
              Lyle
              • Chuck S.
                • March 31, 1992
                • 4668
                I have also observed swirl marks on new rings; if the swirls are uniform and in the same direction/angle all around the entire ring, then I agree those are probably buffing marks from the factory. They probably aren't going to come out with rubbing compound if they are buff marks.
