C2 Battery Spacers - NCRS Discussion Boards
C2 Battery Spacers
  • Craig C.
    • July 31, 1996
    • 27
    C2 Battery Spacers
    Are battery spacers correct for 1966, if so do they go in the corners of the battery tray? I do not see them pictured in the AIM. I bought a set from a vendor and I want to install my battery correctly. Thanks, Craig
    • 43290
    Re: C2 Battery Spacers
    Craig-----
    If what you're talking about are small plastic or rubber pieces, I believe these are attached to the corners of the battery HOLD-DOWN bracket. I don't think these were ever used in PRODUCTION, although it's possible they were part of the original hold-down brackets. Not to my recollection, though.
    • Timothy B.
      • April 30, 1983
      • 5203
      Craig,
      I think the spacers were to be install on 63 corvette's but they make the positive battery cable dangerously close the the top battery shield. There is a 1963 TSB (I believe) to remove them if this condition exists and I don't know if they were used after 63.
      • Craig C.
        • July 31, 1996
        • 27
        Joe and Timothy, Excellent, thank you.
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1463
          They were not present on any of the original MY's I have seen.
          HaND
          • Robert I.
            • July 31, 2004
            • 164
            How are they attached to the battery hold-down tray? Glue?
              • 6960
              Originally posted by Timothy Barbieri (6542)
              Craig,
              Craig, I am with Tim, early 63 had them and then went away because of positive cable grounding out. Would not use them.
              • Robert I.
                • July 31, 2004
                • 164
                "Craig, I am with Tim, early 63 had them and then went away because of positive cable grounding out. Would not use them."
                Yes, I got them via Ebay and I'm going to return them.
                • Mike M.
                  Director Region V
                  • August 31, 1994
                  • 1463
                  Yep, Tim nailed it.
                  FYI to answer Bob's second question, there were not cemented.
                  Just held in place by tightening down the top bracket.
                  Originals were rubber.
                  HaGD
