We've had a zillion threads on oil and engine breakin, but the subject of this one is what did GM use for "breakin oil" back in the vintage era.
My '63 AIM shows lubrication symbol "3a" on Sheet A3.00 Sect. 6 and Sect. 14 lists "3a" as "3845679 engine oil" 1375 gal. per 1000 jobs, which is 5.5 quarts per job.
The sheet change record dated 1-23-63 indicates the previous engine oil number was 3814873 and the prior quantity "was 1250 gal [per 1000 jobs] base & L-75", so the quantity change must have been recognition that the actual quantity per job varied with the mix of engine options because L-76 and L-84 had a quart more capacity than base and L-75.
So if St. Louis added engine oil, then Flint must have drained the oil out of engines after the hot fire test and prior to shipment. Did they use the same oil for the next hot fire test?
Back then I always understood that the plants used some sort of "breakin oil" and thought is was basically just common SAE 20-20W API MS oil of the sixties.
Was this oil actually the same as any store bought 20-20W MS oil of the era?
Was 3814873/3845679 a special blend that incorporated more anti-wear additive?
The single number indicates the same oil was used year round. Is this the case? What about cars shipped to the upper Midwest in winter?
