Jack differences - NCRS Discussion Boards
Jack differences
  • Tom L.
    • May 7, 2007
    • 438
    Jack differences
    My '70 jack is pretty rusty. I'm debating the restoration of my original vs. buying a replacement. I found a replacement with an acceptable date (I think) that's in good shape; however, the threads are different. My original has fine threads while the one I'm considering purchasing has coarse threads. What's the difference b/t the fine and coarse threaded jacks? Is the coarse threaded jack correct for a '70 or could the coarse threaded unit be from an '80? Thanks.
    • 43219
    Re: Jack differences
    Tom-----
    Is the replacement jack you found otherwise identical to the original jack in all aspects of configuration other than the jack screw thread type? The GM #3958710 jack was used in PRODUCTION only through the 1979 model year. It was still manufactured for a short while after that for SERVICE, but I think it would be unlikely to find a 3958710 jack with a 1980 date code.
    • Tom L.
      • May 7, 2007
      • 438
      Joe,
      It looks to be identical but for the threads on the screw. Does the coarse thread unit have a different part number than the fine thread jack? Thanks.
      Tom
        • 43219
        Joe,
        Tom
        Tom-----
        I'm not familiar with a change in threads. It may be that the 3958710 went through a change in specifications for the jack screw at some point. I believe that the replacement jack used for 1980-82 had a different configuration that the 3958710.
        • Dan H.
          • July 31, 1977
          • 1369
          Hi, just wondering about a jack I had in my 64 which is totally later than the correct one. It is dated 9J27, has a warning sticker on it but I can't find a part number so not sure what it fits. Has a fine thread screw, original paint etc. The whole jack is longer than a 64 jack. Are there any other ID marks on these later jacks? Thanks,
          Dan
          1964 Red FI Coupe, DUNTOV '09
          • Chuck S.
            • April 1, 1992
            • 4668
            Is the date stamp the same format as your original jack? Depending on your build date, the date format should be 9* or 0*, where * is an alphabetic letter for the month.
            • Harmon C.
              • August 31, 1994
              • 3228
              1980 jacks were dated 0 B 20 0=80 B=Feb 20=day of the month. If the jack has no day of the month on it then it is not a 1980 jack but it could be a 70. I have seen a different thread on some service jacks but they look nothing like an original jack.
              Lyle
              • Chuck S.
                • April 1, 1992
                • 4668
                ...My original has fine threads while the one I'm considering purchasing has coarse threads. What's the difference b/t the fine and coarse threaded jacks? Is the coarse threaded jack correct for a '70 or could the coarse threaded unit be from an '80? Thanks.
                OK...Back to your original question: Coarse thread??!! Fine thread??!!
                My late 70 jack, and I expect ALL 70 jacks, has 9 acme threads per inch on the screw. A 70 date code will be a single digit ("0") for year, and a letter (A-G) for month.
                • Tom L.
                  • May 7, 2007
                  • 438
                  Thanks everyone.
