Knob of clock - NCRS Discussion Boards
Knob of clock
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12887
    Knob of clock
    How do I remove the knob of a '63 clock to replace the glass?
    greetings,
    Rob.
    Rob.
    NCRS Software Developer
  • Gary C.
    Administrator
    • October 1, 1982
    • 17971
    Re: Knob of clock
    Rob, hold the knob with a pair of pliers taped up to it won't mar the clock stem and turn the knob to the left. If it's too tight you might have to use a pair of taped up pliers on it also or spray it with CRC Freeze Off to loosen the knob up. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Stewart A.
      • April 16, 2008
      • 1035
      Re: Knob of clock
      Garry your right on the money with that. I just had my rebuilt clock apart because there was a piece of lint behind glass that was completly doing my head in. So I pulled the knob out held the stem with a taped up pair of pliers and turned the knob anti clockwise and bingo it unscrewed.
      Hey Rob what are you doing with a 63 clock thats not your year.
      Don't tell me you have crossed to the dark side.
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12887
        Re: Knob of clock
        Hi Stewart,
        I did cross the dark side, have a look at http://www.c2registry.org/index.php?...d=10&order=asc and let the force be with you...
        haha,
        Rob.
        Rob.
        • Mike B.
          • November 1, 2004
          • 389
          Re: Knob of clock
          When you put it back together, use a dab of blue Locktite on the threads. This way it will not unscrew if you happen to turn the knob counterclockwise.
          • Rob M.
            NCRS IT Developer
            • January 1, 2004
            • 12887
            Re: Knob of clock
            Hi gary,
            I haev tried to get the konb of using your instructions but it is Sooooo stuck. I'll put some WD40 on it tonight and let it soak and hopefully I can get it of tomorrow. Otherwise I'm afraid I can't replace the glass (or I have cut the axle and put a new one in from a donor clock).
            PS does anyone has such a part (including the little gear since mine is missing 1 teeth).
            greetings,
            Rob.
            Rob.
            • Gary C.
              Administrator
              • October 1, 1982
              • 17971
              Re: Knob of clock
              Rob, see if you can find this product http://www.crcindustries.com/auto/content/fzo.aspx
              It works great. If not go to a pharmacy and get some "wart remover", the kind that freezes off warts. It's basically the same and will produce the same result. With CRC Freeze Off I would spray it 3-4 times in 5 minute increments and then try it. I have unstuck some really stuck steel screws in aluminum very easily after using Freeze Off. Before Freeze Off I used to use the wart remover. Trick learned from an old machinist.
              The gears are probably available from one of the clock restorers. Send me a photo on e-mail and will check around and let you know what I find out.
              Gary
              NCRS Texas Chapter
              • Stewart A.
                • April 16, 2008
                • 1035
                Re: Knob of clock
                Hey Rob just throw it in the trash its only a 63 clock. Ha Ha
                I had a look at your pictures looks like a good starter for a clean up
                I think the best looking car I've ever seen besides my 60 (not)was a black split window. They have a look no other car has I look forward to lots of progressive photos.
                • Rob M.
                  NCRS IT Developer
                  • January 1, 2004
                  • 12887
                  Re: Knob of clock
                  Ok, I've been able to remove the knob, after applying some WD40 and an overnight soak. Next is ordering a fresh lense and I'm also considering to replace the outer ring and knob.
                  Rob.
                  • Rob M.
                    NCRS IT Developer
                    • January 1, 2004
                    • 12887
                    Re: Knob of clock
                    I've got the glass and chrome/silver ring now replaced and the inner ring repainted (semi-gloss black) and this is the end-result.
                    Rob.
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17971
                      Re: Knob of clock
                      Rob, way tooo coooo clock and hat! Congratulations on both! Gary....
                      NCRS Texas Chapter
