66 427/425 4 barrel secondary - NCRS Discussion Boards
  • Ted K.
    • August 31, 1994
    • 337
    At what point does the secondary open up? I cannot get my secondary to open while the car is stationary. I can goose the heck out of the carb from under the hood and there is no movement of the secondary linkage.
    I have replaced the secondary diaphragm and checked the vacuum openings to the primary and secondaries. Everything moves freely as it should.
    I can't tell if they open when driving the car because the sound of the sidepipes overwhelms the usual droan of the 4 barrels when they are open.
    Thanks, Ted
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 66 427/425 4 barrel secondary
    Thanks, Ted
    Ted, testing in the garage, you would probably see the secondary throttle plates open about 3000 or 4000 RPM after the engine explodes. It's actually a slightly delayed action.
    To assure that the secondaries are functioning, put a bit of clay on the opening stop of the secondary lever and drive the car. Most likely, you'll find that they operate properly and a depression in the clay.
    • Bill I.
      • January 29, 2008
      • 554
      Hello Ted. You will never get the back 2 barrels to open while the car is sitting. It only happens under load, like running through 2nd & 3rd gears. I Have side pipes also, you will "feel" them opening under load, the car pulls harder. I had the same concerns also, but trust be, if everything is set right, no vac leaks, you'll feel it. Do agree, miss the sound of a Holley sucking 600 cfm. Bill.
        • 43279
        Thanks, Ted
        Ted-----
        I'll bet there were THOUSANDS of Holley 4 barrel carbs converted to mechanical secondaries because their owners were convinced the "secondaries were not opening" due to a "test" just like yours. I KNOW there was at least ONE "once-upon-a-time" so-converted. It was a STUPID thing to do even for that guy that I KNOW once did it. And, pretty much, it was a stupid thing to do for all the others, too.
        • Ted K.
          • August 31, 1994
          • 337
          Thanks for the comments. I believe it is working as I can feel a little surge kick in around 3500 -4000 rpm wide open, but will try the clay trick to see if it opens up all the way.
          Ted
