I have a 65 SB. What should the distance/clearance be from the ground to the pipes just behind the frame's cross member (where the pipes go thru the frame) ? I've just put on a set of Paragon's pipes and they seem to be significantly lower than my stock pipes. Having trouble getting out of my slanted garage exit now...
I currently have 3 1/2" clearance which is way low. Anyone else have issues with Paragon pipes ? I don't see how I can possibly adjust them to raise them (mainly by rotating) w/o messing up the angle at which they meet up with the one-position-only mufflers.
Thanks, Mark
Thanks, Mark
