I need some help understanding the high idle mechanism on my 396. My car is always climate controlled started so I have really never thought much of the "cold start" for this car. It fires up so easy and idles steady wherever I set the RPM. I do get a slight RPM increase with oil warmup but not significant (500-1000). Once I start the car the motor holds heat very well so to do any testing takes almost a complete day before I would consider it cold. The motor is hot but the carb doesn't feel warm even after several minutes running. In addition the tube that provides warm air from the exhaust manifold also is not hot. How long would the car need to run before the idle would "kick" down. On the 3124 the butterfly is controlled by the choke where you can lean the carb (plastic adjuster). What actually creates the carb to set an idle that is higher at the start of a cold engine? There is no connection between the throttle and the butterfly. It must only be controlled by heat. If this is the case when started in what position would the butterfly be and where would it end up once warm. It stays in about a 45 degree position all the time. Does the butterfly actually make the idle higher? Really struggling with the concept.
