Judging a Powerglide - NCRS Discussion Boards
  • Tyler T.
    • August 31, 1981
    • 282
    My 55 has a 3 speed in it which is incorrect. What year PG can I use and not lose judging points? I have a line on a 58, would that work?
    Thanks.
    Tyler
  • Fenwick B.
    • January 1, 2005
    • 115
    Re: Judging a Powerglide
    Tyler, My 53 to72 Corvette Specifications Guide shows that the only Powerglide transmission that 55 to 61 Corvettes had was a cast-iron Powerglide transmission built at Cleveland, with a transmission code of C. I take this as all Corvette Powerglides from 55 to 61 were the same. The actual transmission codes are not judged. Passenger car transmissions will work, but the tail section needs to be changed.
    Fenwick Binder
    • Tyler T.
      • August 31, 1981
      • 282
      Thanks.
      Tyler
      • Roy B.
        • February 1, 1975
        • 7044
        Thanks.
        Tyler
        All PG's are not the same ,55 dint use a vacuum modulator or a vacuum line. 58 did!
        • Gary C.
          Administrator
          • October 1, 1982
          • 17916
          Tyler, buy it if it has the Corvette tailshaft on it. That's the higher dollar part and VERY hard to find! Then buy a '57 passenger car powerglide. They are readily available at most swap meets. Good luck, Gary....
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Tyler T.
            • August 31, 1981
            • 282
            Its a passanger car so guess I will pass. I think I know of a 58 cvette one though, thanks for the info.
            Tyler
