There is a 63 340 HP intake on Ebay GM PN 3794129, and I could use some opinions about it.
Behind the carb on the passenger side there is usually an undrilled boss on the top of the casting. I read in Nolands restoration book that sometimes there is no cast boss. It also appears that sometimes the boss is drilled and plugged using a threaded plug. Does the situation exist where the casting without the boss is also drilled and plugged?
Ebay item #230250080582 is drilled and plugged but has no boss, could this be a legitimate GM part in it's present configuration?
