C1 fan noise - NCRS Discussion Boards
C1 fan noise
  • Matt F.
    • June 30, 2002
    • 79
    C1 fan noise
    Even with a fan clutch recently installed, I still get a LOT of fan noise on my '60.
    Do I have unrealistic expectations, 'cause I can change?!!
    -Matt
    • 43246
    Re: C1 fan noise
    -Matt
    Matt-----
    Assuming that you have the correct fan installed and the correct (or, near correct) fan clutch installed, I'd say you have unrealistic expectations of what the fan noise ought to be.
    If you are using a GM #3770529 fan blade assembly and a GM #3916141 fan clutch, that's as close as you're going to get to original specs.
    • Matt F.
      • June 30, 2002
      • 79
      Re: C1 fan noise
      Thanks Joe -
      I kinda thought that might be the case. Just wanted to make sure that these things weren't running quietly right off the assembly line.
      When I'm ready for a new exhaust system, I'll just have to get one that's loud enough so I can't hear the fan!
      Thanks for your input...
      -Matt
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        C1 fan noise
        Matt - I agree with your planned answer to dealing with excessive fan noise. Works every time. And can also get rid of lousy Wonderbar AM radio reception issues - not to mention irritating squeaks and rattles throughout the car. Of course, ear plugs or my hearing can do the same thing.
        • Vinnie P.
          Editor NCRS Restorer Magazine
          • May 31, 1990
          • 1571
          Re: C1 fan noise
          Or do like the the dipstick does and install a fiberglass fan on all his cars...
