The right dash indicator on my 1974 works fine. The left blows the #1895 bulb consistently. At first I thought it was just a bad bulb but I went through two new today before not taking that exercise any further. The actual/external turn signal lights front and rear on both sides work fine. So why is the right indicator light OK and the left troublesome?
1974 Problem-Turn Signal Indicator on Dash
Re: 1974 Problem-Turn Signal Indicator on Dash
PAUL-
I just noticed last night that my left t.s. indicator bulb is out on my 74. All the external bulbs and functions are fine. How does one go about replacing it. Seems kinda tight under there. This is the first time for mine in 7 years, and I haven't been into the dash on my car yet. Perhaps yours is a issue of jarring the bulb (being so tight under there) during installation and the filiments are touching each other and shorting out?
Marty- Top
Marty,
You can get at it. I used a flashlight and a mirror to locate it (light blue single wire), then got my hand up there without losing too much blood.
I tested the bulbs with the socket hanging down loose so jarring is not the problem. I bought some more #1895 bulbs this morning and will fool about this afternoon but would certainly appreciate comments here so I don't just blow more bulbs.
*Edit*-Re hanging loose, I am wondering if I have lost ground for that bulb socket by not reconnecting it to the dashboard??Last edited by Paul L.; May 10, 2008, 09:46 AM.- Top
Yes, the ground is via the dashboard if it is attached with a single wire.Bill Clupper #618- Top
. By testing the bulbs with the socket hanging loose I was dealing with an incomplete circuit.
All is well now and the left turn signal indicator is happily showing flashing green. My thanks for the comments!- Top
