59 road draft tube - NCRS Discussion Boards
59 road draft tube
  • Robert D.
    • April 1, 2003
    • 305
    59 road draft tube
    just wondering for an early 59 what is the correct draft tube. the TIM&JG manual just states 2 45 degree brazed tubes at the engine connection area(equals 90 degree) and the lower end cut at an angle. during my research i see 2 different ones. the difference seems to be one with a straight and one with a little bend in the part that runs along the top of the engine. the one on my car is the one that is straight. is this correct or do i need the other style to pass judging? if so will the aftermarket ones pass judging?
    thanx
    bob defalco
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 59 road draft tube
    I believe 56 to 62 draft tube head original was a round design and later was not. Hope others jump in.
      It's believed there are early and late versions of the road draft tube with the change in fabrication taking place around late '59/early '60. Two pictures here depict the difference that deals the construction of the tube's intake head.
      The early version (first picture) had a 45-degree angle crimp while the later version used a single piece intake head that was crimped at the tube. The early version of the part is notorious for separating along the 45-degree crimp line with time, age, handling....
      • Roy B.
        • February 1, 1975
        • 7044
        So I had it wrong, you say the round head was a later design?
        • Mike E.
          • February 28, 1975
          • 5141
          Jack--
          My experience has been the opposite. I know that 62 had the 2 45-degree pieces for sure--and believe that later 60 and 61 did also.
          • Mike M.
            • May 31, 1974
            • 8408
            our 56, both 57's and our 61, the four having their original crankcase vent tubes,have the two 45 degree type tubes.mike
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11364
              '62 #483 has the 45` style...... Rich
              ps when I opened the hood to take a pic, as I was curious, mr. spidey was too.
              • Mike M.
                • May 31, 1974
                • 8408
                rich: does the spider moniter your oil pressures? what's with the bolt in the block? regards,mike
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11364
                  ...no, he keeps one leg up on the temperature. The prior owner blocked off the oil pipe fitting. Just another thing to deal with when I get to take this wreck apart.
                  At least I won't have to spring for a new road draft tube. Is that bolt that holds mine on original? No markings on it.
                  Rich
                  • Mike M.
                    • May 31, 1974
                    • 8408
                    most of the c-1 CCVT's fastners have a small E embossed at the 3 oclock position. I think a small S amy also have been used. when you clean off that bolt, i'd guess its got an alpha character, based on the washer(which looks like the real mccoy) under your hex bolt.mike
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      Re: 59 road draft tube "jack"
                      OK so I was correct but the 62 is not a round head??
                      • Mike E.
                        • February 28, 1975
                        • 5141
                        The 62 is not a round head. Hold-down bolt also can be RBW.
                        • Mike M.
                          • May 31, 1974
                          • 8408
                          no you weren't correct. your original post stated the 56 to 62 draft tubes were round. the 56 to 62's were not round. mike
                          • Robert D.
                            • April 1, 2003
                            • 305
                            is that a brown recluse spider? if so the most poisonous in the US. holy crap be careful!!!
                            • Roy B.
                              • February 1, 1975
                              • 7044
                              Mike thanks for the info ,I needed that
