I'm in the final stages of dressing the engine for paint. I've already applied the first coat will now install the exhaust manifolds, water pump and harmonic balancer. I'm having trouble identify whether this engine came from the factory with french locks at the front and rear or the exhaust manifolds. The 1965 Judging Guide says nothing regarding the L78 having them, but I've photographed a '65 / 396 car built within days of the one that I am restoring that went through flight at the '05 National Meet that had french locks on the manifolds. So are they supposed to be there or not?
The other questions are whether the bracket that bolts to the left side intake manifold for the throttle return spring and the vacuum line braket located on the right side of the engine are to be installed on the engine and painted when the engine is painted? The final question is the upper right water pump attaching stud supposed to be painted orange or was it installed later at St. Louis and natural in color? See attached pictures, that have the items circled.
Any help would be greatly appreciated.
Thanks to Keith Burmeister for the use of these pictures.
James West
James West
