Thanks to Martin Novak - Follow up Question - NCRS Discussion Boards
  • Robert S.
    • June 30, 2001
    • 230
    Thanks to Martin's suggestion I quickly got to the filter and changed it. I noticed the plastic cover over the bottom of the cannister has a place for a hose to be attached. Mine has no hose. Is that correct for a 74'?
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Thanks to Martin Novak - Follow up Question
    I have never seen a hose on the bottom cover.
    Lyle
      • 3416
      Robert and Lyle,
      My 71 has a 5" long piece of hose, with a spring clamp, on the bottom nipple. The only thing that comes to mind is 'drain'? UPC 8, Sheet B 5, in the 71 AIM, does show it. So, that means for 74....?
      • Robert S.
        • June 30, 2001
        • 230
        I looked tonight, and the 74' AIM shows the hose routing and mounting for the charcoal cannister - It shows no hose connected to the lower cover. I should have checked the AIM prior to my post.
