I have a 66' with standard disc brakes. I noticed that the brake pedal was starting to feel soft so I bled the brakes and it felt good for awhile then started to feel soft again after several hundred miles of use. I checked the master cylinder and I had not lost any fluid. I bled them again and the same thing happened. I did get a little air out of the left rear caliper though. I had replaced the rubber lines not to long ago and they still look in good shape. I next thought the master cylinder was bad, so I replace it with a new one and it did the same thing with the new master cylinder. I can not see any signs of brake fluid at any of the wheels. I am not using silicon brake fluid, but regulat dot 4 fluid. The pads are all in good shape. Could this be a caliper problem. I put new calipers on all four wheels with the stainless steel sleves some years back.
