Car in question is a 1965 St. Louis bodied roadster. When both seats are locked in the "full rearward" position, and seatbacks are upright, should there be approximately equal clearance between the outboard seatback edges and the quarter trim panels?
On the passenger side, the outboard "hockey stick" rubs against the trim panel, and on the driver's side, there is about 3/4" clearance. Both seat bottoms give same "bubble" reading as the console top, when a level is placed across all three items. Both seat bottoms look to be well matched, as far as side-to-side orientation, between console and inner door panels. If the rear seat mounts are shimmed to equalize clearance of both seats, then there is a slight difference in the side-to-side (roll) angle of the two seats.
My suspicion is that a wide variation in clearance between both seats is acceptable. Would some of you "eyeball" or measure yours for comparison? Don't forget to check "roll" attitude of the seatbacks.
Thanks in advance.
Joe
Thanks in advance.
Joe
