67 BB smog pump - NCRS Discussion Boards
67 BB smog pump
  • Chris L.
    • January 1, 1994
    • 44
    67 BB smog pump
    Tring to find a smog pump for my 67 bb coupe with no luck. Am I searching for something that's made of "Unobtaineum" here ??? Any Ideas would be appreciated. Thanks, Chris
    • 43247
    Re: 67 BB smog pump
    Chris-----
    1966-67 Corvette AIR pumps use a configuration that's unique to Corvettes. However, they are not all that hard to find---the same pumps were used for big blocks or small blocks. I'm sure that Bill Hodel can fix you up with one without too much trouble.
    Now, if you need the mixture control valve ("diverter valve") or the pump bracket, that's another story entirely. Bill Hodel may be able to fix you up with these, too, but it definitely won't be inexpensive.
