Differences in a C1 and C2 Ballast Resistor - NCRS Discussion Boards
  • M W.
    • July 31, 2001
    • 835
    Are there any major differences in the the two resistors if used on the same relative low horse car? Basically would a 62 work for a 64? Both being 327 low horse.
    Craig W.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Differences in a C1 and C2 Ballast Resistor
    Craig W.
    Yes! but the design will differ
      C1's and C2's used the same 0.3-ohm ballast resistor (#1931385) through January, 1963. In early February, 1963, 250-300hp cars changed to a 1.8-ohm ballast resistor (#1957154) to reduce point-burning in cold weather.
      • Roy B.
        • February 1, 1975
        • 7044
        1955 only Corvette or Car first design
        • Mike M.
          • May 31, 1974
          • 8407
          the ballast resistor in your picture(roy b) is not 55 only as your post states.. that configuration of the porcelain is what i like to see on the 56 and 57 vettes.mike
          • M W.
            • July 31, 2001
            • 835
            Could a C1 ballast resistor be used on on a 64?
            Craig W.
              Craig W.
              Functionally, yes.
              • Roy B.
                • February 1, 1975
                • 7044
                I'll say your correct ,my brain is on 55. This ballast first design is rarely ever seen. I depend on you after 1955 ,cant afford those newer $$$ Corvettes
